Saltar al contenido principal
Nintendo DSi XL Motherboard Replacement
Qué necesitas
  1. Nintendo DSi XL Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Motherboard Replacement: paso 2, imagen 1 de 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Motherboard Replacement, Lower Case: paso 3, imagen 1 de 3 Nintendo DSi XL Motherboard Replacement, Lower Case: paso 3, imagen 2 de 3 Nintendo DSi XL Motherboard Replacement, Lower Case: paso 3, imagen 3 de 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Motherboard Replacement: paso 5, imagen 1 de 3 Nintendo DSi XL Motherboard Replacement: paso 5, imagen 2 de 3 Nintendo DSi XL Motherboard Replacement: paso 5, imagen 3 de 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Motherboard Replacement: paso 6, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 6, imagen 2 de 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Motherboard Replacement: paso 7, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 7, imagen 2 de 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Motherboard Replacement, Wi-Fi Board: paso 8, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement, Wi-Fi Board: paso 8, imagen 2 de 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Nintendo DSi XL Motherboard Replacement: paso 9, imagen 1 de 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  10. Nintendo DSi XL Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  11. Nintendo DSi XL Motherboard Replacement: paso 11, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 11, imagen 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Nintendo DSi XL Motherboard Replacement: paso 12, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 12, imagen 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Nintendo DSi XL Motherboard Replacement: paso 13, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 13, imagen 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Nintendo DSi XL Motherboard Replacement: paso 14, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 14, imagen 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  15. Nintendo DSi XL Motherboard Replacement: paso 15, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 15, imagen 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Nintendo DSi XL Motherboard Replacement: paso 16, imagen 1 de 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  17. Nintendo DSi XL Motherboard Replacement: paso 17, imagen 1 de 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  18. Nintendo DSi XL Motherboard Replacement: paso 18, imagen 1 de 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Nintendo DSi XL Motherboard Replacement: paso 19, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 19, imagen 2 de 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Nintendo DSi XL Motherboard Replacement: paso 20, imagen 1 de 2 Nintendo DSi XL Motherboard Replacement: paso 20, imagen 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
Conclusión
20 personas más completaron esta guía.
Brett Hartt
Miembro Desde 04/12/10
128,242 Reputación
143 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,067 Guías creadas
Un comentario
Just brilliant! Done in one go! Saved £20! Thanks indeed for good people!
Aidas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 26
Ultimos 30 días: 166
Todo El Tiempo: 34,286
