Saltar al contenido principal
Nintendo DS Lite Battery Replacement
Qué necesitas
  1. Nintendo DS Lite Battery Replacement, Battery: paso 1, imagen 1 de 2 Nintendo DS Lite Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Battery Replacement: paso 2, imagen 1 de 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
Conclusión
46 personas más completaron esta guía.
Matthew Newsom
Miembro Desde 01/05/10
39,500 Reputación
67 Guías creadas
5 comentarios
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - Contestar
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - Contestar
Thanks but will a dsi battery work
Zach - Contestar
My battery cover won’t come off.
Jake - Contestar
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 37
Ultimos 7 días: 175
Ultimos 30 días: 915
Todo El Tiempo: 53,306
