Saltar al contenido principal
Nintendo DS Bottom LCD Screen Replacement
Qué necesitas
  1. Nintendo DS Bottom LCD Screen Replacement, Battery: paso 1, imagen 1 de 3 Nintendo DS Bottom LCD Screen Replacement, Battery: paso 1, imagen 2 de 3 Nintendo DS Bottom LCD Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Bottom LCD Screen Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Bottom LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Bottom LCD Screen Replacement, Back Panel: paso 4, imagen 1 de 1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Bottom LCD Screen Replacement: paso 5, imagen 1 de 3 Nintendo DS Bottom LCD Screen Replacement: paso 5, imagen 2 de 3 Nintendo DS Bottom LCD Screen Replacement: paso 5, imagen 3 de 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Nintendo DS Bottom LCD Screen Replacement, Motherboard replacement.: paso 6, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Bottom LCD Screen Replacement: paso 7, imagen 1 de 3 Nintendo DS Bottom LCD Screen Replacement: paso 7, imagen 2 de 3 Nintendo DS Bottom LCD Screen Replacement: paso 7, imagen 3 de 3
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Nintendo DS Bottom LCD Screen Replacement: paso 8, imagen 1 de 2 Nintendo DS Bottom LCD Screen Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Nintendo DS Bottom LCD Screen Replacement: paso 9, imagen 1 de 2 Nintendo DS Bottom LCD Screen Replacement: paso 9, imagen 2 de 2
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Bottom LCD Screen Replacement: paso 10, imagen 1 de 1
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
  11. Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: paso 11, imagen 1 de 2 Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: paso 11, imagen 2 de 2
    • Peel off the black cushion foam on the bottom touch screen to expose the ribbon cable.
    • Gently lift the screen out of the base.
Conclusión
22 personas más completaron esta guía.
dnguye26
Miembro Desde 10/28/09
710 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-3, Maness Fall 2009 Miembro de Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
Miembros de 4
31 Guías creadas
2Guía Comentarios
I like it but add a step 12 maybe, to see how to put in a new screen.
Zackary Benton - Contestar
Why was this unfinished guide published?
Or was it just mistitled?
"How to 'almost' remove the lower screen"
mgoerlich1990 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 56
Ultimos 30 días: 380
Todo El Tiempo: 45,437
