Saltar al contenido principal
Nintendo DS Back Panel Replacement
Qué necesitas
  1. Nintendo DS Back Panel Replacement, Battery: paso 1, imagen 1 de 3 Nintendo DS Back Panel Replacement, Battery: paso 1, imagen 2 de 3 Nintendo DS Back Panel Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Back Panel Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Back Panel Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Back Panel Replacement, Back Panel: paso 4, imagen 1 de 1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Back Panel Replacement: paso 5, imagen 1 de 3 Nintendo DS Back Panel Replacement: paso 5, imagen 2 de 3 Nintendo DS Back Panel Replacement: paso 5, imagen 3 de 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
Conclusión
17 personas más completaron esta guía.
dnguye26
Miembro Desde 10/28/09
694 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-3, Maness Fall 2009 Miembro de Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Miembros
28 Guías creadas
2 comentarios
Where do I get a nintendo DS gamepak?
Kayla Maison - Contestar
Kayla Maison , a gamepak is simply a GBA game.
Bob - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 28
Ultimos 30 días: 96
Todo El Tiempo: 17,557
