Saltar al contenido principal
Nintendo 64 Motherboard Replacement
Qué necesitas
  1. Nintendo 64 Motherboard Replacement, Top Cover: paso 1, imagen 1 de 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Motherboard Replacement: paso 2, imagen 1 de 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Motherboard Replacement: paso 5, imagen 1 de 1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Motherboard Replacement, Metal Plate: paso 6, imagen 1 de 2 Nintendo 64 Motherboard Replacement, Metal Plate: paso 6, imagen 2 de 2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Motherboard Replacement: paso 7, imagen 1 de 2 Nintendo 64 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Motherboard Replacement: paso 11, imagen 1 de 2 Nintendo 64 Motherboard Replacement: paso 11, imagen 2 de 2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Motherboard Replacement: paso 12, imagen 1 de 2 Nintendo 64 Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Motherboard Replacement: paso 13, imagen 1 de 2 Nintendo 64 Motherboard Replacement: paso 13, imagen 2 de 2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Motherboard Replacement: paso 14, imagen 1 de 1
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Motherboard Replacement, Motherboard: paso 15, imagen 1 de 1
    • Remove the four screws indicated using the #1 Phillips screwdriver.
  16. Nintendo 64 Motherboard Replacement, Motherboard removal: paso 16, imagen 1 de 1
    • Lift up and remove the motherboard.
Conclusión
36 personas más completaron esta guía.
tonymag28
Miembro Desde 10/28/09
2,154 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-4, Regan Fall 2009 Miembro de Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Miembros
15 Guías creadas
3 comentarios
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Contestar
i got the second comment :whyy:
Sqwerks - Contestar
What are the symptoms of a bad motherboard?
Jon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 149
Ultimos 30 días: 539
Todo El Tiempo: 63,649
