Saltar al contenido principal
Nintendo 64 Rumble Pak Battery Replacement
Qué necesitas
  1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: paso 1, imagen 1 de 1
    • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
  2. Nintendo 64  Rumble Pak Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
  3. Nintendo 64  Rumble Pak Battery Replacement: paso 3, imagen 1 de 1
    • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
    • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
  4. Nintendo 64  Rumble Pak Battery Replacement: paso 4, imagen 1 de 3 Nintendo 64  Rumble Pak Battery Replacement: paso 4, imagen 2 de 3 Nintendo 64  Rumble Pak Battery Replacement: paso 4, imagen 3 de 3
    • Check for corrosion around the springs and the flat plate where the batteries touch.
    • Do not touch the corrosion. It may be battery acid.
    • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
    • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
Conclusión
Carly Bowen
Miembro Desde 07/20/15
280 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 3-6, Rauch SU 2015 Miembro de Texas Tech, Team 3-6, Rauch SU 2015
TTU-RAUCH-SU15S3G6
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 41
Todo El Tiempo: 3,604
