Saltar al contenido principal
Nintendo 3DS Microphone Replacement
Qué necesitas
  1. Nintendo 3DS Microphone Replacement, Back Cover: paso 1, imagen 1 de 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Microphone Replacement: paso 2, imagen 1 de 2 Nintendo 3DS Microphone Replacement: paso 2, imagen 2 de 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Microphone Replacement, Battery: paso 3, imagen 1 de 3 Nintendo 3DS Microphone Replacement, Battery: paso 3, imagen 2 de 3 Nintendo 3DS Microphone Replacement, Battery: paso 3, imagen 3 de 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Microphone Replacement, Lower Case: paso 4, imagen 1 de 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Microphone Replacement: paso 5, imagen 1 de 3 Nintendo 3DS Microphone Replacement: paso 5, imagen 2 de 3 Nintendo 3DS Microphone Replacement: paso 5, imagen 3 de 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS Microphone Replacement, Microphone: paso 6, imagen 1 de 2 Nintendo 3DS Microphone Replacement, Microphone: paso 6, imagen 2 de 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  7. Nintendo 3DS Microphone Replacement: paso 7, imagen 1 de 2 Nintendo 3DS Microphone Replacement: paso 7, imagen 2 de 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  8. Nintendo 3DS Microphone Replacement: paso 8, imagen 1 de 2 Nintendo 3DS Microphone Replacement: paso 8, imagen 2 de 2
    • Lift the microphone and its attached ribbon cable off the motherboard.
    • If your replacement microphone doesn't come with a silicone cover, peel the cover off the original one and reuse it.
Conclusión
3 personas más completaron esta guía.
David Hodson
Miembro Desde 04/13/10
150,493 Reputación
127 Guías creadas
2 comentarios
Can someone please tell me how to acquire a new microphone chip?
Grimmy Animates - Contestar
You are able to purchase replacement microphones on amazon for less than $10 USD
Julianne McBride -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 81
Todo El Tiempo: 9,753
