Saltar al contenido principal
Nintendo 3DS Battery Replacement
Qué necesitas
  1. Nintendo 3DS Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Battery Replacement: paso 2, imagen 1 de 2 Nintendo 3DS Battery Replacement: paso 2, imagen 2 de 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: paso 3, imagen 1 de 3 Nintendo 3DS Battery Replacement, Battery: paso 3, imagen 2 de 3 Nintendo 3DS Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
Conclusión
45 personas más completaron esta guía.
David Hodson
Miembro Desde 04/13/10
150,503 Reputación
127 Guías creadas
7 comentarios
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - Contestar
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - Contestar
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - Contestar
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 58
Ultimos 7 días: 447
Ultimos 30 días: 2,189
Todo El Tiempo: 67,714
