Introducción
Replacing the motherboard should be a last resort and shouldn't be taken lightly. There are many delicate ribbon cables so be careful and go slow.
Qué necesitas
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Reorient the device so that the game slot now faces you.
Remove the two rubber bumpers along the top of the device using tweezers.
Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
Locate the joystick assembly near the top right corner of the motherboard.
Remove the two 8mm Phillips #00 screws from the back of the joystick.
Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
Remove the power cable, indicated by the black and red wires, by gently pulling it up and out of the connector.
Gently pull the ribbon cables out of the 4 ZIF connectors.
Lift the retaining tab and remove the large ribbon cable on the left side of the motherboard.
Lift the retaining tab and remove the large ribbon cable on the top of the motherboard behind the infrared receiver.
Lift the retaining tab and remove the large ribbon cable on the top of the motherboard just above the joysitck housing.
6 personas más completaron esta guía.
