Introducción
If you aren't getting full range of motion on the D pad replacing may fix it. Go slow. There are several delicate ribbons cables. Make sure that components are completely disconnected before you pull them apart.
Qué necesitas
Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Locate the gamecard reader near the bottom right corner of the motherboard.
Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
Remove the four 3mm Phillips #00 screws from the four corners of the D pad board.
Lift the D pad board out of the device.
4 comentarios
Thanks for pointing that out! I think it is fixed now.
-Tyler
