Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The motherboard houses all the internal circuitry of the Nintendo 2DS, and the utmost caution must be taken when disassembling it. Be certain not to strip any screws, as that damage my be impossible to fix.
Partes
No se especificaron partes.
  1. Remove the two Phillips screws securing the upper rear panel.
    • Remove the two Phillips screws securing the upper rear panel.
    • The screws will not completely detach from the back panel.
  2. Hinge the upper rear panel upwards and outwards to remove it. Hinge the upper rear panel upwards and outwards to remove it.
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
  4. Remove the ten Phillips screws attaching the rear panel.
    • Remove the ten Phillips screws attaching the rear panel.
  5. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  6. The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  7. Carefully flip the back panel over to locate the attached ribbon cable.
    • Carefully flip the back panel over to locate the attached ribbon cable.
    • Remove the two Phillips screws attaching the ribbon cable to the rear panel.
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
  8. Hold the side panels of the device's case with your fingers and pull outward to remove them. The panels should come off easily with little force required.
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
  9. Remove the 12 brass-colored Phillips screws securing the main board.
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
  10. The top panel can only be removed when the mother board is not secured. There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail. There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
  11. Detach the 2 ribbon cables by lifting the black flip connectors that hold them. Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
Conclusión
22 personas más completaron esta guía.
Fina Beauchamp
Miembro Desde 12/01/15
2,506 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 70-1, Forte Winter 2015 Miembro de Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Miembros
27 Guías creadas
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
thiagopereira10000 - Contestar
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
Mark Damien English - Contestar
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
briana1987be - Contestar
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Steve David -
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Danielle Chester - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 93
Ultimos 30 días: 422
Todo El Tiempo: 37,075
