Saltar al contenido principal
Ninja Ultima BL810 Vent Replacement
Qué necesitas
  1. Ninja Ultima BL810 Vent Replacement, Power Plug: paso 1, imagen 1 de 3 Ninja Ultima BL810 Vent Replacement, Power Plug: paso 1, imagen 2 de 3 Ninja Ultima BL810 Vent Replacement, Power Plug: paso 1, imagen 3 de 3
    • Unscrew the Phillips #0 11mm screws.
    • Unscrew the Torx Security #10 11mm screw.
  2. Ninja Ultima BL810 Vent Replacement: paso 2, imagen 1 de 2 Ninja Ultima BL810 Vent Replacement: paso 2, imagen 2 de 2
    • Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
    • Pull the bottom covering off of the blender.
  3. Ninja Ultima BL810 Vent Replacement: paso 3, imagen 1 de 2 Ninja Ultima BL810 Vent Replacement: paso 3, imagen 2 de 2
    • Unscrew the two Phillips #2 9mm screws.
    • Remove the plastic block.
  4. Ninja Ultima BL810 Vent Replacement: paso 4, imagen 1 de 3 Ninja Ultima BL810 Vent Replacement: paso 4, imagen 2 de 3 Ninja Ultima BL810 Vent Replacement: paso 4, imagen 3 de 3
    • Unscrew the four Phillips #2 11mm screws.
    • Remove the plastic covers.
    • Removing the top cover and then rotating the bottom cover into the same orientation works best.
  5. Ninja Ultima BL810 Vent Replacement: paso 5, imagen 1 de 1
    • Unscrew the three Phillips #2 9mm screws.
    • This metal plate doesn't need to be completely removed, just adjusted to the side to continue working.
  6. Ninja Ultima BL810 Vent Replacement: paso 6, imagen 1 de 3 Ninja Ultima BL810 Vent Replacement: paso 6, imagen 2 de 3 Ninja Ultima BL810 Vent Replacement: paso 6, imagen 3 de 3
    • Pull the power cord through as shown to create slack.
    • Remove plastic casing by lifting upwards.
  7. Ninja Ultima BL810 Vent Replacement: paso 7, imagen 1 de 3 Ninja Ultima BL810 Vent Replacement: paso 7, imagen 2 de 3 Ninja Ultima BL810 Vent Replacement: paso 7, imagen 3 de 3
    • Follow the power plug cords to find the right plastic caps.
    • Squeeze the caps with pliers to loosen the grip.
    • Pull the plastic caps off the twisted wires.
  8. Ninja Ultima BL810 Vent Replacement: paso 8, imagen 1 de 3 Ninja Ultima BL810 Vent Replacement: paso 8, imagen 2 de 3 Ninja Ultima BL810 Vent Replacement: paso 8, imagen 3 de 3
    • Untwist the two wires from each other and pull the zip tie off.
  9. Ninja Ultima BL810 Vent Replacement, Vent: paso 9, imagen 1 de 1
    • Unscrew the 2 Phillips #2 9mm screws.
  10. Ninja Ultima BL810 Vent Replacement: paso 10, imagen 1 de 1
    • Grip the vent on either side and lift it straight in the upward direction.
Conclusión
Equipo
Cal Poly, Team S9-G4, Banghart Fall 2017 Miembro de Cal Poly, Team S9-G4, Banghart Fall 2017
CPSU-BANGHART-F17S9G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 888
