Saltar al contenido principal
Ninja Professional Blender BL660 Suction Cups on Base Replacement
Qué necesitas
  1. Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: paso 1, imagen 1 de 2 Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: paso 1, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 5 screws holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Suction Cups on Base Replacement: paso 2, imagen 1 de 2 Ninja Professional Blender BL660 Suction Cups on Base Replacement: paso 2, imagen 2 de 2
    • Turn the base panel upside down to reveal the suction cup feet.
  3. Ninja Professional Blender BL660 Suction Cups on Base Replacement: paso 3, imagen 1 de 1
    • Push the stopper on the suction cup foot through the bottom panel using the iFixit plastic opening tool.
  4. Ninja Professional Blender BL660 Suction Cups on Base Replacement: paso 4, imagen 1 de 2 Ninja Professional Blender BL660 Suction Cups on Base Replacement: paso 4, imagen 2 de 2
    • Once stopper has passed through the bottom panel, pull suction cup foot out.
    • Replace suction cup feet as needed.
    • Ninja does not sell suction cup feet. You will need to obtain them from other third party vendors.
Conclusión
Un comentario
Where did you get the suction cups from?
camoramirez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 61
Todo El Tiempo: 4,971
