Saltar al contenido principal
Ninja Professional Blender BL660 Power Cord Replacement
Qué necesitas
  1. Ninja Professional Blender BL660 Power Cord Replacement, Blender Base: paso 1, imagen 1 de 2 Ninja Professional Blender BL660 Power Cord Replacement, Blender Base: paso 1, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Power Cord Replacement: paso 2, imagen 1 de 2 Ninja Professional Blender BL660 Power Cord Replacement: paso 2, imagen 2 de 2
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Power Cord Replacement: paso 3, imagen 1 de 2 Ninja Professional Blender BL660 Power Cord Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Power Cord Replacement: paso 4, imagen 1 de 2 Ninja Professional Blender BL660 Power Cord Replacement: paso 4, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Power Cord Replacement: paso 5, imagen 1 de 2 Ninja Professional Blender BL660 Power Cord Replacement: paso 5, imagen 2 de 2
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 Power Cord Replacement, Power Cord: paso 6, imagen 1 de 2 Ninja Professional Blender BL660 Power Cord Replacement, Power Cord: paso 6, imagen 2 de 2
    • Check the connection between the power cord and the wires coming from the circuit board.
  7. Ninja Professional Blender BL660 Power Cord Replacement: paso 7, imagen 1 de 2 Ninja Professional Blender BL660 Power Cord Replacement: paso 7, imagen 2 de 2
    • Remove the plastic caps on the wire connectors with your hands.
    • Ensure that the connections are not loose, corroded, or desoldered.
    • If the connections are desoldered, loose, or corroded, re-solder them using the iFixit soldering guide.
  8. Ninja Professional Blender BL660 Power Cord Replacement: paso 8, imagen 1 de 1
    • If the connections in the preceding step are good, check the connection of the wires to the circuit board.
    • If the connections are loose or damaged, the blender may not be getting power.
  9. Ninja Professional Blender BL660 Power Cord Replacement: paso 9, imagen 1 de 1
    • Re-solder the connections using the iFixit Soldering guide.
    • Make sure you check the correct solder points since the wires are routed differently.
Conclusión
2 comentarios
Hello,
I have a question. Do you know where can I buy the power cord for Ninja Blender. The model is BL 770. I have not found it anywhere. I also contacted Ninja Support by phone, but they don't sell this part of the Blender.
Denis Figueiredo - Contestar
Excellent pictures and directions! this made the repair easy
Donald Beers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 42
Todo El Tiempo: 2,100
