Saltar al contenido principal
Ninja Professional Blender BL660 Power Button Panel Replacement
Qué necesitas
  1. Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: paso 1, imagen 1 de 2 Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: paso 1, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Power Button Panel Replacement: paso 2, imagen 1 de 2 Ninja Professional Blender BL660 Power Button Panel Replacement: paso 2, imagen 2 de 2
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Power Button Panel Replacement: paso 3, imagen 1 de 2 Ninja Professional Blender BL660 Power Button Panel Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Power Button Panel Replacement: paso 4, imagen 1 de 2 Ninja Professional Blender BL660 Power Button Panel Replacement: paso 4, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Power Button Panel Replacement: paso 5, imagen 1 de 2 Ninja Professional Blender BL660 Power Button Panel Replacement: paso 5, imagen 2 de 2
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: paso 6, imagen 1 de 3 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: paso 6, imagen 2 de 3 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: paso 6, imagen 3 de 3
    • Using the Phillips #2 screwdriver, remove the four screws holding the circuit board to the housing.
  7. Ninja Professional Blender BL660 Power Button Panel Replacement: paso 7, imagen 1 de 1
    • Using a pair of scissors, cut the zip ties holding the power wires in order to give the circuit board mobility.
  8. Ninja Professional Blender BL660 Power Button Panel Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the 5 screws holding the power button panel cover.
  9. Ninja Professional Blender BL660 Power Button Panel Replacement: paso 9, imagen 1 de 3 Ninja Professional Blender BL660 Power Button Panel Replacement: paso 9, imagen 2 de 3 Ninja Professional Blender BL660 Power Button Panel Replacement: paso 9, imagen 3 de 3
    • Pull the power button panel cover off.
    • The power button panel comes off as a whole unit. Replace as needed.
    • Ninja Kitchen does not sell the power button panel. You will have to purchase one from a third party vendor.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 1,403
