Introducción
If your power button panel doesn't light up, your LED lights may be malfunctioning. This guide will help show the replacement of faulty LED lights under the button panel.
Qué necesitas
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
Using the Phillips #2 screwdriver, remove the four screws (10mm long, 5mm wide) on the circuit board.
Casi Terminas!
Conclusión
