Saltar al contenido principal
Ninja Professional Blender BL660 LED Lights Replacement
Qué necesitas
  1. Ninja Professional Blender BL660 LED Lights  Replacement, Blender Base: paso 1, imagen 1 de 2 Ninja Professional Blender BL660 LED Lights  Replacement, Blender Base: paso 1, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 LED Lights  Replacement: paso 2, imagen 1 de 2 Ninja Professional Blender BL660 LED Lights  Replacement: paso 2, imagen 2 de 2
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 LED Lights  Replacement: paso 3, imagen 1 de 2 Ninja Professional Blender BL660 LED Lights  Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 LED Lights  Replacement: paso 4, imagen 1 de 2 Ninja Professional Blender BL660 LED Lights  Replacement: paso 4, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 LED Lights  Replacement: paso 5, imagen 1 de 2 Ninja Professional Blender BL660 LED Lights  Replacement: paso 5, imagen 2 de 2
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: paso 6, imagen 1 de 3 Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: paso 6, imagen 2 de 3 Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: paso 6, imagen 3 de 3
    • Using the Phillips #2 screwdriver, remove the four screws (10mm long, 5mm wide) on the circuit board.
  7. Ninja Professional Blender BL660 LED Lights  Replacement: paso 7, imagen 1 de 1
    • To give the circuit board further range of motion, remove the pictured zip ties holding the cables.
  8. Ninja Professional Blender BL660 LED Lights  Replacement: paso 8, imagen 1 de 1
    • Locate the malfunctioning LED lights on the circuit board.
  9. Ninja Professional Blender BL660 LED Lights  Replacement: paso 9, imagen 1 de 1
    • Flip the circuit board to view the soldering connections of the LED lights and replace as needed.
    • For instructions on sodering and desoldering reference iFixit's guide.
Conclusión
Un comentario
Buenas tardes.
Muy buenas ilustraciones, pero deben poner los números de partes de los repuestos.
Gracias por la información.
Jose Sosa - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 591
