Introducción
If your blender is too loud, your fan may be damaged or loose. This guide will show you how to replace a broken or damaged fan.
Qué necesitas
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
Use a wrench or a pair of pliers to help remove the nut on top of the fan. Holding the fan itself will help make the process easier.
Un comentario
I did that but the other fan is the one that is lock and do not turn on. The white one in the middle. How can I fix it.
