Saltar al contenido principal
Ninja NJ600 LED Light Replacement
Qué necesitas
  1. Ninja NJ600 LED Light Replacement, Blender Base Cover: paso 1, imagen 1 de 2 Ninja NJ600 LED Light Replacement, Blender Base Cover: paso 1, imagen 2 de 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 LED Light Replacement: paso 2, imagen 1 de 2 Ninja NJ600 LED Light Replacement: paso 2, imagen 2 de 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 LED Light Replacement: paso 3, imagen 1 de 3 Ninja NJ600 LED Light Replacement: paso 3, imagen 2 de 3 Ninja NJ600 LED Light Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 LED Light Replacement, Circuit Board: paso 4, imagen 1 de 1
    • Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
    • Be careful not to scratch the circuit board with the screwdriver.
  5. Ninja NJ600 LED Light Replacement: paso 5, imagen 1 de 1
    • Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
    • This will give the circuit board more range of motion.
  6. Ninja NJ600 LED Light Replacement: paso 6, imagen 1 de 3 Ninja NJ600 LED Light Replacement: paso 6, imagen 2 de 3 Ninja NJ600 LED Light Replacement: paso 6, imagen 3 de 3
    • Desolder the five wires from the solder pads shown.
    • If you do not know how to do this, iFixit has a guide describing the process.
    • Before you begin to desolder these wires, flip the board over to confirm that you are about to desolder the correct component.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 LED Light Replacement: paso 7, imagen 1 de 1
    • After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
    • NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
  8. Ninja NJ600 LED Light Replacement, LED Light: paso 8, imagen 1 de 2 Ninja NJ600 LED Light Replacement, LED Light: paso 8, imagen 2 de 2
    • Locate the LED you wish to desolder.
    • On the bottom of the board, each LED is designated with a small triangle with a line at one tip.
  9. Ninja NJ600 LED Light Replacement: paso 9, imagen 1 de 1
    • Desolder the two LED leads, and remove the LED from the board.
    • NOTE: the LED is a diode, and requires proper orientation when installed.
Conclusión
Nathan Delaney
Miembro Desde 04/01/15
177 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-2, Lancaster Spring 2015 Miembro de Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 382
