Saltar al contenido principal
Ninja NJ600 Fan Replacement
Qué necesitas
  1. Ninja NJ600 Fan Replacement, Blender Base Cover: paso 1, imagen 1 de 2 Ninja NJ600 Fan Replacement, Blender Base Cover: paso 1, imagen 2 de 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Fan Replacement: paso 2, imagen 1 de 2 Ninja NJ600 Fan Replacement: paso 2, imagen 2 de 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Fan Replacement: paso 3, imagen 1 de 3 Ninja NJ600 Fan Replacement: paso 3, imagen 2 de 3 Ninja NJ600 Fan Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Fan Replacement, Fan: paso 4, imagen 1 de 1
    • Hold the fan steady and use a wrench or pliers to remove the nut in the image.
    • The fan is sharp. Use caution when handling with bare hands.
    • A towel or gloves may be useful when holding the fan for this step.
  5. Ninja NJ600 Fan Replacement: paso 5, imagen 1 de 1
    • Hold the fan and use the flathead 4.0 screwdriver to loosen the washer.
    • The fan is sharp, use caution when handling with bare hands.
    • You may use a towel or gloves to avoid handling the fan with your bare hands.
  6. Ninja NJ600 Fan Replacement: paso 6, imagen 1 de 2 Ninja NJ600 Fan Replacement: paso 6, imagen 2 de 2
    • Slide the washer and fan off of the screw.
Conclusión
Ryan Heller
Miembro Desde 04/01/15
107 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-2, Lancaster Spring 2015 Miembro de Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,369
