Saltar al contenido principal
Ninja NJ600 Button Replacement
Qué necesitas
  1. Ninja NJ600 Button Replacement, Blender Base Cover: paso 1, imagen 1 de 2 Ninja NJ600 Button Replacement, Blender Base Cover: paso 1, imagen 2 de 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Button Replacement: paso 2, imagen 1 de 2 Ninja NJ600 Button Replacement: paso 2, imagen 2 de 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Button Replacement: paso 3, imagen 1 de 3 Ninja NJ600 Button Replacement: paso 3, imagen 2 de 3 Ninja NJ600 Button Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Button Replacement, Circuit Board: paso 4, imagen 1 de 1
    • Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
    • Be careful not to scratch the circuit board with the screwdriver.
  5. Ninja NJ600 Button Replacement: paso 5, imagen 1 de 1
    • Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
    • This will give the circuit board more range of motion.
  6. Ninja NJ600 Button Replacement: paso 6, imagen 1 de 3 Ninja NJ600 Button Replacement: paso 6, imagen 2 de 3 Ninja NJ600 Button Replacement: paso 6, imagen 3 de 3
    • Desolder the five wires from the solder pads shown.
    • If you do not know how to do this, iFixit has a guide describing the process.
    • Before you begin to desolder these wires, flip the board over to confirm that you are about to desolder the correct component.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 Button Replacement: paso 7, imagen 1 de 1
    • After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
    • NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
  8. Ninja NJ600 Button Replacement, Button: paso 8, imagen 1 de 2 Ninja NJ600 Button Replacement, Button: paso 8, imagen 2 de 2
    • After removing the circuit board from your device, locate which button you wish to replace.
    • On the opposite side of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
  9. Ninja NJ600 Button Replacement: paso 9, imagen 1 de 1
    • Desolder these four solder pads.
    • These pads are small, so take care to not damage the circuit board.
    • NOTE: the orientation of the buttons is important. Make sure you place the new button in the correct orientation.
Conclusión
To reassemble your device, follow these instructions in reverse order, except soldering when you desoldered previously.
Kody D
Miembro Desde 04/01/15
537 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-2, Lancaster Spring 2015 Miembro de Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Miembros
6 Guías creadas
Un comentario
ZNR1 please help in value
Kalpesh Patel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 1,240
