Saltar al contenido principal
Ninja Mega Kitchen System BL770 LED Light Replacement
Qué necesitas
  1. Ninja Mega Kitchen System BL770 LED Light Replacement, LED Light: paso 1, imagen 1 de 2 Ninja Mega Kitchen System BL770 LED Light Replacement, LED Light: paso 1, imagen 2 de 2
    • On the circuit board, locate the LED light you wish to replace.
    • On the bottom of the board, each LED is designated with a small triangle with a line at one tip and a label of LED1, LED2, etc.
  2. Ninja Mega Kitchen System BL770 LED Light Replacement: paso 2, imagen 1 de 1
    • Desolder the two LED leads to the specific bulb.
    • Remove the LED from the circuit board.
    • Properly install the new LED and solder to the board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 616
