Saltar al contenido principal
Ninja Mega Kitchen System BL770 Cooling Fan Replacement
Qué necesitas
  1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: paso 1, imagen 1 de 2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: paso 1, imagen 2 de 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: paso 3, imagen 1 de 3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: paso 3, imagen 2 de 3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: paso 3, imagen 3 de 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: paso 4, imagen 1 de 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: paso 5, imagen 1 de 2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: paso 5, imagen 2 de 2
    • Using caution, hold the fan steady and use a wrench or pliers to remove the nut securing the fan.
    • Loosen the washer with a flathead screwdriver, then remove the fan and replace with a new one.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 742
