Saltar al contenido principal
Ninja Master Prep QB900B button replacement
Qué necesitas
  1. Ninja Master Prep QB900B button replacement, The Ninja Master Prep QB900B: paso 1, imagen 1 de 1
    • Place the blender to the side.
  2. Ninja Master Prep QB900B button replacement: paso 2, imagen 1 de 2 Ninja Master Prep QB900B button replacement: paso 2, imagen 2 de 2
    • Remove the two highlighted screws with a Phillips #2 Screw Driver
    • Gently pull off the top.
  3. Ninja Master Prep QB900B button replacement, Button: paso 3, imagen 1 de 1
    • Remove the highlighted screws.
  4. Ninja Master Prep QB900B button replacement: paso 4, imagen 1 de 1
    • Pull out the highlighted spring.
    • Now wash the button with soap and water, and follow the guide backwards to reassemble.
Conclusión
2 personas más completaron esta guía.
Kamal Taha
Miembro Desde 08/27/15
679 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-3, Sullivan Fall 2015 Miembro de USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Miembros
5 Guías creadas
2 comentarios
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
Stephen Filippone - Contestar
turns out it was a security torx. how annoying.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,934
