Saltar al contenido principal
Ninja Kitchen System Pulse Motor Replacement
Qué necesitas
  1. Ninja Kitchen System Pulse Motor Replacement, Base Disassembly: paso 1, imagen 1 de 1
    • Take out the three 15 mm Phillips #1 screws.
    • Remove the 15mm T10 screw.
    • Place the 4 screws on the magnetic mat.
  2. Ninja Kitchen System Pulse Motor Replacement: paso 2, imagen 1 de 1
    • Remove the gray base by lifting upwards and placing to the side.
  3. Ninja Kitchen System Pulse Motor Replacement, Motor: paso 3, imagen 1 de 1
    • Remove the three 15 mm Phillips #1 screws.
    • Place screws on magnetic mat.
  4. Ninja Kitchen System Pulse Motor Replacement: paso 4, imagen 1 de 1
    • Remove the motor by gently lifting up. Be careful with the cords, as they may be tangled.
    • This is the entire motor for the Ninja. If you have access to a spare motor, simply swap out the motors.
Conclusión
2 personas más completaron esta guía.
DJ
Miembro Desde 01/20/16
122 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 15-1, Remmell Spring 2016 Miembro de USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Miembros
5 Guías creadas
Un comentario
Dear sir my ninga kitchen system 1100 (blender machine) motor rod is broken i need help to replace it where i can get the rod or repair shop near me thank you
Noman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 4,325
