Introducción
The power cord conducts power to the Coffee Bar; the Coffee Bar cannot function without it, and it can be very dangerous if it is damaged. This guide describes how to replace the power cord.
Qué necesitas
Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
Prepare two crimp connectors by filling them with dielectric grease.
Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
Using a second crimp connector, repeat for the remaining pair of stripped wires.
Using the appropriate crimping tool, crimp the connectors.
The power cord splits into two and feeds into two closed-end crimp connectors. Two wires from your coffee machine also enter these connectors.
Locate the neutral wire that feeds into the crimp connector from the machine. Mark this wire.
Apply dielectric grease to the insides of two new crimp connectors.
Insert the stripped ends of the wire into the crimp connectors.
Locate the ends of the replacement power cord. These should be already stripped; if they are not, strip 2 cm from them using wire strippers.
Feed the ends of the replacement power cord into the crimp connectors. Crimp the connectors using the appropriate crimping tool.
After the wires have been spliced, the new power cord is ready for use with your machine.
Una persona más ha completado esta guía.
