Saltar al contenido principal
Ninja Coffee Bar CF086 Power Cord Replacement
Qué necesitas
  1. Ninja Coffee Bar CF086 Power Cord Replacement, Water Heating Element: paso 1, imagen 1 de 2 Ninja Coffee Bar CF086 Power Cord Replacement, Water Heating Element: paso 1, imagen 2 de 2
    • Make sure the Ninja Coffee Bar is unplugged and that you have a dry, clean workspace for this task.
    • Remove the carafe and water reservoir and set them aside.
  2. Ninja Coffee Bar CF086 Power Cord Replacement: paso 2, imagen 1 de 1
    • Unscrew the T-10 screws from the bottom cover of the machine, and remove that bottom cover.
  3. Ninja Coffee Bar CF086 Power Cord Replacement: paso 3, imagen 1 de 1
    • Unscrew and remove the heating plate layer. This will expose the internal workings of the machine.
  4. Ninja Coffee Bar CF086 Power Cord Replacement: paso 4, imagen 1 de 1
    • Locate the water heating element in the interior of your coffee maker.
    • Unscrew the two indicated J1S1 screws at the base of the water heating element.
  5. Ninja Coffee Bar CF086 Power Cord Replacement: paso 5, imagen 1 de 1
    • Unscrew and remove the remaining J1S1 screws that secure the water heating element to the interior of the device.
  6. Ninja Coffee Bar CF086 Power Cord Replacement: paso 6, imagen 1 de 3 Ninja Coffee Bar CF086 Power Cord Replacement: paso 6, imagen 2 de 3 Ninja Coffee Bar CF086 Power Cord Replacement: paso 6, imagen 3 de 3
    • Grasp and remove the clamp securing the tube that feeds into the base of the water heating element.
    • Detach the tube from the water heating element.
  7. Ninja Coffee Bar CF086 Power Cord Replacement: paso 7, imagen 1 de 2 Ninja Coffee Bar CF086 Power Cord Replacement: paso 7, imagen 2 de 2
    • Locate the coated wire that feeds into the side of the water heating element. Remove this wire.
  8. Ninja Coffee Bar CF086 Power Cord Replacement: paso 8, imagen 1 de 2 Ninja Coffee Bar CF086 Power Cord Replacement: paso 8, imagen 2 de 2
    • Locate the two wires leading out from the water heating element that feed into crimp connectors.
    • Using side cutters, sever these wires near the crimp connectors.
    • Use the side cutters to cut the remaining wires that feed into the crimp connectors from the coffee machine.
  9. Ninja Coffee Bar CF086 Power Cord Replacement: paso 9, imagen 1 de 2 Ninja Coffee Bar CF086 Power Cord Replacement: paso 9, imagen 2 de 2
    • Squeeze and remove the clamp that secures the main tube feeding into the water heating element. Remove that tube.
    • Remove the water heating element.
  10. Ninja Coffee Bar CF086 Power Cord Replacement: paso 10, imagen 1 de 3 Ninja Coffee Bar CF086 Power Cord Replacement: paso 10, imagen 2 de 3 Ninja Coffee Bar CF086 Power Cord Replacement: paso 10, imagen 3 de 3
    • Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
    • Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
  11. Ninja Coffee Bar CF086 Power Cord Replacement: paso 11, imagen 1 de 1
    • Prepare two crimp connectors by filling them with dielectric grease.
    • Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
    • Using a second crimp connector, repeat for the remaining pair of stripped wires.
    • Using the appropriate crimping tool, crimp the connectors.
  12. Ninja Coffee Bar CF086 Power Cord Replacement, Power Cord: paso 12, imagen 1 de 2 Ninja Coffee Bar CF086 Power Cord Replacement, Power Cord: paso 12, imagen 2 de 2
    • The power cord splits into two and feeds into two closed-end crimp connectors. Two wires from your coffee machine also enter these connectors.
    • Locate the neutral wire that feeds into the crimp connector from the machine. Mark this wire.
  13. Ninja Coffee Bar CF086 Power Cord Replacement: paso 13, imagen 1 de 2 Ninja Coffee Bar CF086 Power Cord Replacement: paso 13, imagen 2 de 2
    • Using side cutters, cut the wires from your device below the crimp connectors.
  14. Ninja Coffee Bar CF086 Power Cord Replacement: paso 14, imagen 1 de 3 Ninja Coffee Bar CF086 Power Cord Replacement: paso 14, imagen 2 de 3 Ninja Coffee Bar CF086 Power Cord Replacement: paso 14, imagen 3 de 3
    • Using wire strippers, carefully expose a 2 cm length of the metal wire from each of the cut ends.
  15. Ninja Coffee Bar CF086 Power Cord Replacement: paso 15, imagen 1 de 2 Ninja Coffee Bar CF086 Power Cord Replacement: paso 15, imagen 2 de 2
    • Apply dielectric grease to the insides of two new crimp connectors.
    • Insert the stripped ends of the wire into the crimp connectors.
    • Locate the ends of the replacement power cord. These should be already stripped; if they are not, strip 2 cm from them using wire strippers.
    • Feed the ends of the replacement power cord into the crimp connectors. Crimp the connectors using the appropriate crimping tool.
Conclusión
After the wires have been spliced, the new power cord is ready for use with your machine.
Una persona más ha completado esta guía.
David Ton
Miembro Desde 10/02/17
630 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G5, Thompson Fall 2017 Miembro de USF Tampa, Team S1-G5, Thompson Fall 2017
USFT-THOMPSON-F17S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 3,671
