Saltar al contenido principal
Ninja Coffee Bar CF080 Control Panel Replacement
Qué necesitas
  1. Ninja Coffee Bar CF080 Control Panel Replacement, Heated Plate: paso 1, imagen 1 de 1
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Control Panel Replacement: paso 2, imagen 1 de 2 Ninja Coffee Bar CF080 Control Panel Replacement: paso 2, imagen 2 de 2
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Control Panel Replacement: paso 3, imagen 1 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 3, imagen 2 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 3, imagen 3 de 3
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Control Panel Replacement: paso 4, imagen 1 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 4, imagen 2 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 4, imagen 3 de 3
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Control Panel Replacement: paso 5, imagen 1 de 1
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Control Panel Replacement: paso 6, imagen 1 de 1
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Control Panel Replacement: paso 7, imagen 1 de 2 Ninja Coffee Bar CF080 Control Panel Replacement: paso 7, imagen 2 de 2
    • Remove the heated plate from the machine with easy glide.
  8. Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: paso 8, imagen 1 de 3 Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: paso 8, imagen 2 de 3 Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: paso 8, imagen 3 de 3
    • Remove the nine 0.5cm screws with Phillips #2 screwdriver.
    • Some screws are harder to see due to how deep the holes are.
    • Recommend using Extender 4 with Phillips #2 screwdriver to help unscrew the screws within the deep holes of the machine.
  9. Ninja Coffee Bar CF080 Control Panel Replacement: paso 9, imagen 1 de 2 Ninja Coffee Bar CF080 Control Panel Replacement: paso 9, imagen 2 de 2
    • Remove the two 0.6cm with Phillips #2 screwdriver.
  10. Ninja Coffee Bar CF080 Control Panel Replacement: paso 10, imagen 1 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 10, imagen 2 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 10, imagen 3 de 3
    • Detach various colored cords from one another, using both hands to place thumb and index finger to hold each grip then separate by pulling with the degree of force.
    • There with be 1 blue, 1 black, 1 red and 2 white.
  11. Ninja Coffee Bar CF080 Control Panel Replacement: paso 11, imagen 1 de 2 Ninja Coffee Bar CF080 Control Panel Replacement: paso 11, imagen 2 de 2
    • Remove the black board by maneuvering it through the cords.
  12. Ninja Coffee Bar CF080 Control Panel Replacement: paso 12, imagen 1 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 12, imagen 2 de 3 Ninja Coffee Bar CF080 Control Panel Replacement: paso 12, imagen 3 de 3
    • Grip the bottom end of the panel and pull it towards you to remove the module from the machine.
  13. Ninja Coffee Bar CF080 Control Panel Replacement: paso 13, imagen 1 de 2 Ninja Coffee Bar CF080 Control Panel Replacement: paso 13, imagen 2 de 2
    • Remove the three 0.6cm screws with Phillips #1 screwdriver.
    • They are in the black holes, 1 at the top and two at the bottom.
  14. Ninja Coffee Bar CF080 Control Panel Replacement: paso 14, imagen 1 de 1
    • Remove the black board attached to the module.
  15. Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: paso 15, imagen 1 de 2 Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: paso 15, imagen 2 de 2
    • Unscrew four 1.2cm screws with Phillips #2 screwdriver.
  16. Ninja Coffee Bar CF080 Control Panel Replacement: paso 16, imagen 1 de 2 Ninja Coffee Bar CF080 Control Panel Replacement: paso 16, imagen 2 de 2
    • Carefully remove the control panel from the control module.
  17. Ninja Coffee Bar CF080 Control Panel Replacement: paso 17, imagen 1 de 1
    • Left with the control module.
Conclusión
Una persona más ha completado esta guía.
Jan Chen
Miembro Desde 09/11/17
235 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Miembro de CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 Miembros
5 Guías creadas
Un comentario
This is great an all, but WHERE do you get the new control board?!? Without it this is worthless...
madmikey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 1,866
