Saltar al contenido principal
Ninja Coffee Bar CF080 Brewer Head Replacement
Qué necesitas
  1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: paso 1, imagen 1 de 1
    • Face the coffee machine in front of you.
    • Make sure that the coffee machine is unplugged.
    • Remove the glass carafe as it will not be needed.
  2. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 2, imagen 1 de 1
    • Firmly grab the tab sticking out from the head of the brewer.
  3. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 3, imagen 1 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: paso 3, imagen 2 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: paso 3, imagen 3 de 3
    • With little force, pull the tab of the brewer head in reverse direction.
  4. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 4, imagen 1 de 1
    • Slide off the head in the direction away from the machine.
    • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
  5. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 5, imagen 1 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: paso 5, imagen 2 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: paso 5, imagen 3 de 3
    • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
  6. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 6, imagen 1 de 1
    • Now the brewer head is positioned to where you can seeing the bottom.
  7. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 7, imagen 1 de 2 Ninja Coffee Bar CF080 Brewer Head Replacement: paso 7, imagen 2 de 2
    • Remove the screw with a Phillips #1 screwdriver.
    • Use Phillips #1 screwdriver.
    • Along will come a small black screw cover and spring
  8. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 8, imagen 1 de 1
    • Twist the black lid on top clockwise until it is completely detached.
  9. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 9, imagen 1 de 1
    • With the black upper lid detached, a smaller black cover can be removed without effort.
  10. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 10, imagen 1 de 2 Ninja Coffee Bar CF080 Brewer Head Replacement: paso 10, imagen 2 de 2
    • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
  11. Ninja Coffee Bar CF080 Brewer Head Replacement: paso 11, imagen 1 de 1
    • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
Conclusión
Una persona más ha completado esta guía.
Equipo
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Miembro de CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 990
