Saltar al contenido principal
Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement
Qué necesitas
  1. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement, Water Reservoir Clip: paso 1, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement, Water Reservoir Clip: paso 1, imagen 2 de 2
    • Remove single 6mm #1 Phillips head screw from the side of the unit and four 6mm screws from under the basket area.
  2. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: paso 2, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: paso 2, imagen 2 de 2
    • Gently pry the upper panel up from the unit.
  3. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: paso 3, imagen 1 de 1
    • Inside the panel, remove the two 6mm #1 Phillips head screws. Remove and replace water reservoir clip as necessary.
Conclusión
CJ Berg
Miembro Desde 11/05/18
444 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 808
