Saltar al contenido principal
Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement
Qué necesitas
  1. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Valve Tubes: paso 1, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Valve Tubes: paso 1, imagen 2 de 2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 2, imagen 1 de 1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 3, imagen 1 de 1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 4, imagen 1 de 1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
  5. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Water Heater: paso 5, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Water Heater: paso 5, imagen 2 de 2
    • Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
    • Remove the single 6mm #1 Phillips-head screw from the side of the unit.
  6. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 6, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 6, imagen 2 de 2
    • Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
  7. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 7, imagen 1 de 1
    • Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
  8. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 8, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 8, imagen 2 de 2
    • Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
  9. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 9, imagen 1 de 1
    • Remove heater from unit.
  10. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 10, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement: paso 10, imagen 2 de 2
    • Squeeze clip and separate signal wiring.
    • Using wire stripper/crimping tool, uncrimp wiring connectors
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
  11. Ninja Coffee Bar® Single-Serve System Hot Water Tubing Replacement, Hot Water Tubing: paso 11, imagen 1 de 1
    • Squeeze connector and pull tubing away from heater.
    • Inspect tubing for damage and/or weak spots and replace if necessary.
Conclusión
Kyle Gustafson
Miembro Desde 11/04/18
85 Reputación
1 Guía escrita
Equipo
2 comentarios
what size tubing does this require?
Lemmiwinks Rules - Contestar
Hi Kyle,
Thanks for this. I’m having trouble getting the top to separate. Any suggestions?
S. D. G. - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 2,092
