Saltar al contenido principal
Ninja Coffee Bar® Single-Serve System Frother Replacement
Qué necesitas
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: paso 1, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: paso 1, imagen 2 de 2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: paso 2, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: paso 2, imagen 2 de 2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: paso 3, imagen 1 de 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: paso 3, imagen 2 de 2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: paso 4, imagen 1 de 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: paso 4, imagen 2 de 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: paso 4, imagen 3 de 3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
Conclusión
CJ Berg
Miembro Desde 11/05/18
444 Reputación
4 Guías creadas
Equipo
Un comentario
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 1,502
