Saltar al contenido principal
Nikon N2000 (F301) Battery Compartment Replacement
Qué necesitas
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: paso 2, imagen 1 de 1
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: paso 3, imagen 1 de 1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: paso 4, imagen 1 de 1
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: paso 5, imagen 1 de 1
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 25-26, Garner Spring 2011 Miembro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Miembros
12 Guías creadas
Un comentario
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 21
Ultimos 30 días: 157
Todo El Tiempo: 17,596
