Introducción
If there is a power problem, you may need to reattach wires to the battery compartment or replace it completely. If the problem is Corrosion, just see the guide on corrosion.
  • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
  • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
Agregar Comentario
Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
Agregar Comentario
Pull up on the tab to remove the batteries.
  • Pull up on the tab to remove the batteries.
  • Note: The batteries will probably fall out of their holder.
Agregar Comentario
Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
Agregar Comentario
Remove the battery compartment from the camera.
  • Remove the battery compartment from the camera.
  • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 25-26, Garner Spring 2011 Miembro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Miembros
6 Guías creadas
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 33
Últimos 30 Días: 114
Todo El Tiempo: 9,146
