Introducción
Back case acts as a door to access change out film. It can be easily removed from the device and replaced if it becomes cracked or otherwise unusable.
    • In this guide we will refer to 'left' and 'right' as though the camera is facing away from you.
    • Pull up on the film rewind lever on the top left of the camera to release the back door.
    • Once the door is released, open it completely.
    Agregar Comentario
  1. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Locate the silver tab on the inside of the door hinge. Slide this down to free the hinge and remove it from the camera.
    Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 25-26, Garner Spring 2011 Miembro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 2,171
