Saltar al contenido principal
Nikon D90 Flash Bulb Replacement
Qué necesitas
  1. Nikon D90 Flash Bulb Replacement, Open the Flash: paso 1, imagen 1 de 3 Nikon D90 Flash Bulb Replacement, Open the Flash: paso 1, imagen 2 de 3 Nikon D90 Flash Bulb Replacement, Open the Flash: paso 1, imagen 3 de 3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: paso 2, imagen 1 de 2 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: paso 2, imagen 2 de 2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: paso 3, imagen 1 de 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: paso 3, imagen 2 de 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: paso 3, imagen 3 de 3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: paso 4, imagen 1 de 2 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  5. Nikon D90 Flash Bulb Replacement, Removing the Bulb: paso 5, imagen 1 de 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: paso 5, imagen 2 de 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: paso 5, imagen 3 de 3
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
Conclusión
8 personas más completaron esta guía.
jonothon cawley
Miembro Desde 10/20/14
354 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Miembros
6 Guías creadas
2 comentarios
thanks for instruction…………really helpfull
hebi - Contestar
Hi guys do you know where to get this bulb?please help
Martin Mitter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 41
Todo El Tiempo: 7,122
