Saltar al contenido principal
Nikon D80 Rear LCD Screen Replacement
Qué necesitas
  1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: paso 1, imagen 1 de 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: paso 1, imagen 2 de 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: paso 1, imagen 3 de 3
    • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
  2. Nikon D80 Rear LCD Screen Replacement: paso 2, imagen 1 de 3 Nikon D80 Rear LCD Screen Replacement: paso 2, imagen 2 de 3 Nikon D80 Rear LCD Screen Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable away from the main body of the camera using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Rear LCD Screen Replacement: paso 3, imagen 1 de 2 Nikon D80 Rear LCD Screen Replacement: paso 3, imagen 2 de 2
    • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
    • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
  4. Nikon D80 Rear LCD Screen Replacement: paso 4, imagen 1 de 2 Nikon D80 Rear LCD Screen Replacement: paso 4, imagen 2 de 2
    • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
    • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
  5. Nikon D80 Rear LCD Screen Replacement: paso 5, imagen 1 de 2 Nikon D80 Rear LCD Screen Replacement: paso 5, imagen 2 de 2
    • Slide out the LCD screen by pulling towards the right.
    • Remove the LCD screen.
    • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
Conclusión
Una persona más ha completado esta guía.
Sara Martin
Miembro Desde 10/09/17
586 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 33
Todo El Tiempo: 2,974
