Saltar al contenido principal
Nikon D80 Main Board Replacement
Qué necesitas
  1. Nikon D80 Main Board Replacement, Main Board: paso 1, imagen 1 de 2 Nikon D80 Main Board Replacement, Main Board: paso 1, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: paso 2, imagen 1 de 3 Nikon D80 Main Board Replacement: paso 2, imagen 2 de 3 Nikon D80 Main Board Replacement: paso 2, imagen 3 de 3
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: paso 3, imagen 1 de 3 Nikon D80 Main Board Replacement: paso 3, imagen 2 de 3 Nikon D80 Main Board Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: paso 4, imagen 1 de 2 Nikon D80 Main Board Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: paso 5, imagen 1 de 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: paso 6, imagen 1 de 3 Nikon D80 Main Board Replacement: paso 6, imagen 2 de 3 Nikon D80 Main Board Replacement: paso 6, imagen 3 de 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
Conclusión
2 personas más completaron esta guía.
Sara Martin
Miembro Desde 10/09/17
577 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Miembros
5 Guías creadas
Un comentario
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 43
Todo El Tiempo: 2,223
