Saltar al contenido principal
Nikon D80 Flash Assembly Replacement
Qué necesitas
  1. Nikon D80 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 1 de 3 Nikon D80 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 2 de 3 Nikon D80 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 3 de 3
    • Press the highlighted button to pop the flash up.
    • Otherwise, use a plastic opening tool to gently lever open the flash by inserting the tool into the gap between the flash and the camera.
  2. Nikon D80 Flash Assembly Replacement: paso 2, imagen 1 de 1
    • Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
  3. Nikon D80 Flash Assembly Replacement: paso 3, imagen 1 de 2 Nikon D80 Flash Assembly Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, pry open the cover.
    • Be advised, some plastic struts may snap off when you remove the cover.
  4. Nikon D80 Flash Assembly Replacement: paso 4, imagen 1 de 2 Nikon D80 Flash Assembly Replacement: paso 4, imagen 2 de 2
    • Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Use caution while using the hot soldering iron.
  5. Nikon D80 Flash Assembly Replacement: paso 5, imagen 1 de 1
    • Gently remove the flash assembly from the casing.
    • The surface may still be hot, so grab it with caution.
Conclusión
Kevin Horwedel
Miembro Desde 10/09/17
211 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G1, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 2,167
