Introducción
In the event that the bottom cover is damaged or specific wires require access, the bottom cover needs to be removed or replaced. For safety purposes, please remove the battery before working with any electronic components.
Qué necesitas
Use the #00 Phillips-head screwdriver to remove the three 8.44 mm screws.
Use the #00 Phillips-head screwdriver to remove the four 6.3 mm screws.
Use the #00 Phillips-head screwdriver to remove the 2.9 mm screw.
5 personas más completaron esta guía.
