Saltar al contenido principal
Nikon D7100 Headphone/Microphone Replacement
Qué necesitas
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: paso 1, imagen 1 de 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Headphone/Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Headphone/Microphone Replacement: paso 3, imagen 1 de 1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Headphone/Microphone Replacement: paso 4, imagen 1 de 1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Headphone/Microphone Replacement: paso 5, imagen 1 de 1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Headphone/Microphone Replacement: paso 6, imagen 1 de 1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Headphone/Microphone Replacement: paso 7, imagen 1 de 1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Headphone/Microphone Replacement: paso 8, imagen 1 de 1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Headphone/Microphone Replacement: paso 9, imagen 1 de 2 Nikon D7100 Headphone/Microphone Replacement: paso 9, imagen 2 de 2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Headphone/Microphone Replacement: paso 10, imagen 1 de 1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Headphone/Microphone Replacement: paso 11, imagen 1 de 1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Headphone/Microphone Replacement: paso 12, imagen 1 de 2 Nikon D7100 Headphone/Microphone Replacement: paso 12, imagen 2 de 2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Headphone/Microphone Replacement: paso 13, imagen 1 de 1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: paso 14, imagen 1 de 1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Headphone/Microphone Replacement: paso 15, imagen 1 de 1
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Headphone/Microphone Replacement: paso 16, imagen 1 de 1
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Headphone/Microphone Replacement: paso 17, imagen 1 de 1
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: paso 18, imagen 1 de 1
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
Conclusión
Una persona más ha completado esta guía.
Wesley Eveld
Miembro Desde 02/20/18
732 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S11-G6, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G6, Cheng Spring 2018
USFT-CHENG-S18S11G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 1,071
