Saltar al contenido principal
Nikon D7100 Dial mode button Replacement
Qué necesitas
  1. Nikon D7100 Dial mode button Replacement, LCD Screen: paso 1, imagen 1 de 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Dial mode button Replacement: paso 2, imagen 1 de 1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Dial mode button Replacement: paso 3, imagen 1 de 1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Dial mode button Replacement: paso 4, imagen 1 de 1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Dial mode button Replacement: paso 5, imagen 1 de 1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Dial mode button Replacement: paso 6, imagen 1 de 1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Dial mode button Replacement: paso 7, imagen 1 de 1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Dial mode button Replacement: paso 8, imagen 1 de 1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Dial mode button Replacement: paso 9, imagen 1 de 2 Nikon D7100 Dial mode button Replacement: paso 9, imagen 2 de 2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Dial mode button Replacement: paso 10, imagen 1 de 1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Dial mode button Replacement: paso 11, imagen 1 de 1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Dial mode button Replacement: paso 12, imagen 1 de 2 Nikon D7100 Dial mode button Replacement: paso 12, imagen 2 de 2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Dial mode button Replacement: paso 13, imagen 1 de 1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Dial mode button Replacement, Motherboard: paso 14, imagen 1 de 1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Dial mode button Replacement: paso 15, imagen 1 de 1
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Dial mode button Replacement: paso 16, imagen 1 de 1
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Dial mode button Replacement: paso 17, imagen 1 de 1
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Dial mode button Replacement, Headphone and Microphone Module: paso 18, imagen 1 de 1
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
  19. Nikon D7100 Dial mode button Replacement, Dial Mode Button: paso 19, imagen 1 de 1
    • Remove these 5 screws along the top of camera body.
  20. Nikon D7100 Dial mode button Replacement: paso 20, imagen 1 de 1
    • Remove these 2 screws on the top of the camera and pull the top screen, flash, and dial-mode button from the main body of the camera.
  21. Nikon D7100 Dial mode button Replacement: paso 21, imagen 1 de 1
    • Remove the screws holding the dial-mode PCB board down.
  22. Nikon D7100 Dial mode button Replacement: paso 22, imagen 1 de 1
    • Remove the potentiometer and PCB off together.
  23. Nikon D7100 Dial mode button Replacement: paso 23, imagen 1 de 1
    • Remove the large screw in the middle of the dial-mode button. This allows you to replace it.
Conclusión
6 personas más completaron esta guía.
Wesley Eveld
Miembro Desde 02/20/18
732 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S11-G6, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G6, Cheng Spring 2018
USFT-CHENG-S18S11G6
4 Miembros
6 Guías creadas
7 comentarios
Thanks for the write up! I just used it to replace my D7100 mode dial.
One caveat, in step 19, there are no screws under the circles that are drawn. Those screws were removed to get the LCD off, I ended up removing several other screws (some unnecessarily I believe) before I was able to get the top panel to separate from the main body.
There are 2 screws on the sides that definitely need to be removed as they clearly hold the top panel to the body. One of these is visible underneath the strap retainer in photo 18. The other one is the same location on the SD card slot side of the body.
edit - I’m also unsure why this shows how to remove the LCD from the back plate as this is unnecessary for replacing the mode dial.
Matt Hayward - Contestar
Okay write up. I tried this and it took me forever to figure out how to disassemble the camera, in the end it wasn’t worth it. The steps after step 18 are just missing information/wrong.
E H - Contestar
All was going well until taking the top screen off. Pulled the top off and wires pulled out from some where most likely have a pile of parts. In reality a !#^& poor explaintion.
CHEEPER TO SEND IT TO NIKON.
chris - Contestar
Many thanks for a good clear guide! I used steps 1 to 10 to remove the base and back so that I could change out the worn buttons around the display. The only problem I had was reconnecting the ribbon cables. After a bit of research I found that you need to flip up the dark grey tabs on the ribbon cable connectors with your fingernail to release the clamps before removing the cables. When reassembling ensure the cables are fully reinserted then push the tabs back down to lock.
Stephen Lipiec - Contestar
My D7200 plate indicator popped off, I just bought the new switch / replacement switch, gently popped off the indicator plate (to know what mode you’re in) and reglued it onto my old rotating dial.
My rotating switch IS broken though, in the sense that it will rotate from indent to indent and the push down switch doesn’t stop it, but I don’t care. It stays where it’s supposed to and I always check what mode I’m in anyways before starting.
I did NOT want to go through the steps above to disassemble my camera, just for the indicator plate. Not worth it.
William Dayton - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 39
Todo El Tiempo: 8,009
