Saltar al contenido principal
Nikon D7000 Tripod Plate Replacement
Qué necesitas
  1. Nikon D7000 Tripod Plate Replacement, Motherboard: paso 1, imagen 1 de 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Tripod Plate Replacement: paso 2, imagen 1 de 1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Tripod Plate Replacement: paso 3, imagen 1 de 2 Nikon D7000 Tripod Plate Replacement: paso 3, imagen 2 de 2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Tripod Plate Replacement: paso 4, imagen 1 de 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Tripod Plate Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Tripod Plate Replacement: paso 6, imagen 1 de 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Tripod Plate Replacement: paso 7, imagen 1 de 1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Tripod Plate Replacement: paso 8, imagen 1 de 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Tripod Plate Replacement: paso 9, imagen 1 de 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Tripod Plate Replacement: paso 10, imagen 1 de 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Tripod Plate Replacement: paso 11, imagen 1 de 1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Tripod Plate Replacement: paso 12, imagen 1 de 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Tripod Plate Replacement: paso 13, imagen 1 de 1
    • Carefully lift the back case off.
  14. Nikon D7000 Tripod Plate Replacement: paso 14, imagen 1 de 3 Nikon D7000 Tripod Plate Replacement: paso 14, imagen 2 de 3 Nikon D7000 Tripod Plate Replacement: paso 14, imagen 3 de 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Tripod Plate Replacement: paso 15, imagen 1 de 2 Nikon D7000 Tripod Plate Replacement: paso 15, imagen 2 de 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Tripod Plate Replacement: paso 16, imagen 1 de 1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Tripod Plate Replacement: paso 17, imagen 1 de 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Tripod Plate Replacement: paso 18, imagen 1 de 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Tripod Plate Replacement: paso 19, imagen 1 de 3 Nikon D7000 Tripod Plate Replacement: paso 19, imagen 2 de 3 Nikon D7000 Tripod Plate Replacement: paso 19, imagen 3 de 3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Tripod Plate Replacement: paso 20, imagen 1 de 2 Nikon D7000 Tripod Plate Replacement: paso 20, imagen 2 de 2
  21. Nikon D7000 Tripod Plate Replacement: paso 21, imagen 1 de 1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Tripod Plate Replacement: paso 22, imagen 1 de 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Tripod Plate Replacement: paso 23, imagen 1 de 1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Tripod Plate Replacement: paso 24, imagen 1 de 1
    • Lift the motherboard off.
  25. Nikon D7000 Tripod Plate Replacement, Tripod Plate: paso 25, imagen 1 de 1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Tripod Plate Replacement: paso 26, imagen 1 de 1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
Conclusión
Una persona más ha completado esta guía.
Jed Chen
Miembro Desde 04/01/15
1,796 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-6, Lancaster Spring 2015 Miembro de Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,375
