Saltar al contenido principal
Nikon D700 Screen Replacement
  1. Nikon D700 Screen Replacement, Screen: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    iOpener
    $19.99
    Comprar
    • Use a spudger and your hands to remove the front grip cover, held together by an adhesive.
    • You may need to use heat to loosen up the adhesive. Try using the iOpener.
    • Under the rubber cover, use a screwdriver to remove one screw on the top right corner.
  2. Nikon D700 Screen Replacement: paso 2, imagen 1 de 2 Nikon D700 Screen Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the five screws that hold the cover in place.
  3. Nikon D700 Screen Replacement: paso 3, imagen 1 de 1
    • Gently remove the screen by pulling the top away from the body.
    • The screen is connected by wires on the bottom, so be careful when taking the screen off.
  4. Nikon D700 Screen Replacement: paso 4, imagen 1 de 3 Nikon D700 Screen Replacement: paso 4, imagen 2 de 3 Nikon D700 Screen Replacement: paso 4, imagen 3 de 3
    Comprar
    • To remove the screen entirely, use a spudger to unlock the connectors.
    • Pull the cables out gently using tweezers or your spudger.
  5. Nikon D700 Screen Replacement: paso 5, imagen 1 de 2 Nikon D700 Screen Replacement: paso 5, imagen 2 de 2
    • The screen should be completely detached from the camera and can now be replaced with a new screen.
Conclusión
Leandro Neves
Miembro Desde 03/20/23
206 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 59
Todo El Tiempo: 720
