Introducción
Use this guide to replace a cosmetically damaged port cover or to install a new rubber port seal.
Qué necesitas
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
Remove the 3.8 mm silver Phillips screw securing the port cover to the side of the D70.
4 personas más completaron esta guía.
