Saltar al contenido principal
Nikon D70 Front Cover Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Nikon D70 Front Cover Replacement, Front Cover: paso 1, imagen 1 de 1
    • Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
  2. Nikon D70 Front Cover Replacement: paso 2, imagen 1 de 1
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Nikon D70 Front Cover Replacement: paso 3, imagen 1 de 1
    • Remove the two 4.3 mm Phillips screws on the face of the front cover.
  4. Nikon D70 Front Cover Replacement: paso 4, imagen 1 de 1
    • Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
  5. Nikon D70 Front Cover Replacement: paso 5, imagen 1 de 2 Nikon D70 Front Cover Replacement: paso 5, imagen 2 de 2
    • Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch.
    • Pull the automatic/manual focus switch away from the front cover.
  6. Nikon D70 Front Cover Replacement: paso 6, imagen 1 de 1
    • If present, remove the plastic cover from the lens mount.
  7. Nikon D70 Front Cover Replacement: paso 7, imagen 1 de 1
    • Pull the front cover away from the D70.
Linea de Meta
0 Guide Comments
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,878
