Saltar al contenido principal
Nikon D610 Battery Replacement
Qué necesitas
  1. Nikon D610 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • First, power off the device.
  2. Nikon D610 Battery Replacement: paso 2, imagen 1 de 3 Nikon D610 Battery Replacement: paso 2, imagen 2 de 3 Nikon D610 Battery Replacement: paso 2, imagen 3 de 3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Battery Replacement: paso 3, imagen 1 de 2 Nikon D610 Battery Replacement: paso 3, imagen 2 de 2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
Conclusión
Daniel Eagan
Miembro Desde 02/10/16
606 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-4, Lacy Spring 2016 Miembro de USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 Miembros
6 Guías creadas
Un comentario
This is my kind of fixing )
Loic - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,470
