Saltar al contenido principal
Nikon D5100 Memory Card Replacement
  1. Nikon D5100 Memory Card Replacement, Memory Card: paso 1, imagen 1 de 3 Nikon D5100 Memory Card Replacement, Memory Card: paso 1, imagen 2 de 3 Nikon D5100 Memory Card Replacement, Memory Card: paso 1, imagen 3 de 3
    • Open the memory card compartment door, located to the right of the digital display, by using your thumb to push it in the direction of the arrow.
  2. Nikon D5100 Memory Card Replacement: paso 2, imagen 1 de 1
    • Eject the memory card by pressing it into its slot until you hear a soft "click."
  3. Nikon D5100 Memory Card Replacement: paso 3, imagen 1 de 1
    • Using thumb and forefinger, gently remove the SD card from its slot.
Conclusión
Liz
Miembro Desde 04/25/14
1,311 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 10-54, Amido Spring 2014 Miembro de Cal Poly, Team 10-54, Amido Spring 2014
CPSU-AMIDO-S14S10G54
4 Miembros
5 Guías creadas
Un comentario
isn't this procedure in the user manual?
Happy Fixer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 26
Todo El Tiempo: 2,414
