Saltar al contenido principal
Nikon D5100 Battery Door Replacement
Qué necesitas
  1. Nikon D5100 Battery Door Replacement, Battery Door: paso 1, imagen 1 de 3 Nikon D5100 Battery Door Replacement, Battery Door: paso 1, imagen 2 de 3 Nikon D5100 Battery Door Replacement, Battery Door: paso 1, imagen 3 de 3
    • Insert the battery into the battery compartment at the bottom of the camera.
  2. Nikon D5100 Battery Door Replacement: paso 2, imagen 1 de 3 Nikon D5100 Battery Door Replacement: paso 2, imagen 2 de 3 Nikon D5100 Battery Door Replacement: paso 2, imagen 3 de 3
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
  3. Nikon D5100 Battery Door Replacement: paso 3, imagen 1 de 3 Nikon D5100 Battery Door Replacement: paso 3, imagen 2 de 3 Nikon D5100 Battery Door Replacement: paso 3, imagen 3 de 3
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
  4. Nikon D5100 Battery Door Replacement: paso 4, imagen 1 de 1
    • The metal bar should be attached and tightly secured.
  5. Nikon D5100 Battery Door Replacement: paso 5, imagen 1 de 2 Nikon D5100 Battery Door Replacement: paso 5, imagen 2 de 2
    • Turn on the camera to check that the battery is properly secure.
Linea de Meta
Michelle Tran
Miembro Desde 02/24/15
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 23-1, Green Winter 2015 Miembro de Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 Miembros
4 Guías creadas
Un comentario
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 32
Todo El Tiempo: 2,767
