Saltar al contenido principal
Nikon D5000 Battery Door Replacement
  1. Nikon D5000 Battery Door Replacement, Battery Door: paso 1, imagen 1 de 2 Nikon D5000 Battery Door Replacement, Battery Door: paso 1, imagen 2 de 2
    • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
  2. Nikon D5000 Battery Door Replacement: paso 2, imagen 1 de 2 Nikon D5000 Battery Door Replacement: paso 2, imagen 2 de 2
    • Grip and hold the front end of the battery door at a 45-degree angle from the case.
    • Pop the battery door out by pulling the front tab up.
    • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
Conclusión
2 personas más completaron esta guía.
Jacob Rardin
Miembro Desde 04/14/14
1,390 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-28, Maness Spring 2014 Miembro de Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Miembros
7 Guías creadas
Un comentario
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 78
Todo El Tiempo: 5,108
